raja.cedt wrote on Nov 26th, 2009, 10:45pm:hi,
so you are advising me to keep buffers outside of the loop, but all my buffer's all are adding lot of noise, so what i feel is if i keep buffers in side the loop, that will get filtered by loop.
Rajasekhar.
No, No, No - All of the noise within the bandwidth of the control loop will get reduced by the control loop. Considering the PLL tends to be low BW that is not going to help you a lot.
Actually pretty useless in my opinion, and I have designed a lot of PLL's
Start thinking about how switching noise in your environment is going to affect things. For ring oscillator PLL's your performance is going to be totally dominated by the interference/switching noise issues and not the inherent (thermal, flicker) noise issues.
