Aug 16th, 2024, 11:02pm
Clock buffer in PLL (Read 5126 times)
raja.cedt
Clock buffer in PLL
Nov 24th, 2009, 6:06am
hi,
   whenever PLL has to drive heavy loads, generally we keep clock buffers at the vco. Now the question in wehter to keep buffer in the loop or outside the loop?  i feel in keeping in side the loop will increase the loop delay but buffer's noise will get high pass filtered. So can any one please explain this.
Rajasekhar.
Re: Clock buffer in PLL
Reply #1 - Nov 24th, 2009, 7:16am
I don't understand meaning of your situation and question.
But I put buffer out of loop.
If I include buffer into loop, loop will be largely affected by load of buffer and then make instable of loop or unlock of loop.
Also it is difficult to design proper loop filter.
[VCO]--[Buffer or  Power Splitter]---[Buffer]---[Freq Divider]--[PFD]--[CP]
                                             ---[Buffer]---[Load or Next Circuit to be drived]
Reply #2 - Nov 26th, 2009, 4:44pm
Fully differential PLL (talking ring oscillator here) with differential to single ended converter ***outside*** the VCO loop and then a feedback divider that is independent of the output buffering totally.
Don't let the buffer system be any part of the PLL system. Get it far away.
Jerry
raja.cedt
Reply #3 - Nov 26th, 2009, 10:45pm
hi,
   so you are advising me to keep buffers outside of the loop, but all my buffer's all are adding lot of noise, so what i feel is if i keep buffers  in side the loop, that will get filtered by loop.
Rajasekhar.
Reply #4 - Nov 27th, 2009, 4:38am
raja.cedt wrote on Nov 26th, 2009, 10:45pm:
Which noise is dominant, PM or AM ?
Reply #5 - Nov 30th, 2009, 9:25am
hi,
Rajasekhar.
No, No, No - All of the noise within the bandwidth of the control loop will get reduced by the control loop. Considering the PLL tends to be low BW that is not going to help you a lot.
Actually pretty useless in my opinion, and I have designed a lot of PLL's
Start thinking about how switching noise in your environment is going to affect things. For ring oscillator PLL's your performance is going to be totally dominated by the interference/switching noise issues and not the inherent (thermal, flicker) noise issues.
