Aug 15th, 2024, 4:39am
verilog-AMS (Read 298 times)
sree 4all
bangalore
verilog-AMS
Dec 01st, 2009, 4:40am
hi
can any one please help me on this topic
" can full custom design can cope up with the challenges of language based design such as verilog-AMS",
please explain this in detailed with some web links to get some information regarding this topic.
Riad KACED
Swindon, UK
Re: verilog-AMS
Reply #1 - Dec 1st, 2009, 8:28am
verilog-AMS is a behavioral modeling language that is very useful to validate a concept, a system before even having the transistor level building blocs. verilog-AMS is very useful to be considered in a Top-down design approach. You can also use verilog-AMS to simulate your final chip within a mixed signal environment like AMS Designer. It allows faster simulations by selecting the most appropriate abstraction level for each of the analog/digital blocs to achieve the required accuracy. So we need both. verilog-AMS can't do everything on it's own. Besides, I don't know any synthesis tool that dumps physical design out of a verilog-AMS module. So waiting for this magic tool to be invented, I can only see a bright future for Custom Design Smiley
As for the links, I think searching 'Behavioral modeling' and/or Verilog-AMS on the Internet would do.
Cheers,
Riad.
Riad KACED
PDK, EDA Support Engineer.
sree 4all
bangalore
Re: verilog-AMS
Reply #2 - Dec 1st, 2009, 10:51am
SmileyRAID KACED
thank you very much for your comment in verilog-AMS
i need some material upon industrial usage, applications,advantages,disadvantages and llimitation of verilog-AMS.
will u please help me on this please.
rajdeep
UK
Re: verilog-AMS
Reply #3 - Dec 2nd, 2009, 3:45am
You might like to read this article/paper...
http://www.designers-guide.org/Design/top-down.pdf
cheers!
Rajdeep
Re: verilog-AMS
Reply #4 - Dec 2nd, 2009, 8:02am
Analog Verification uses Verilog-AMS to verify the whole SOC. This is explained in papers referenced in http://www.designers-guide.com/documents.html.
somisetty
Re: verilog-AMS
Reply #5 - Dec 8th, 2009, 2:10am
Can you provide verilogA code of Parallel in Serial out shift registers.
Thanks inadvance
