Aug 15th, 2024, 10:55am
Cadence ADE-XL: loading a previously saved ocean script (Read 4017 times)
vivkr
Dec 02nd, 2009, 7:46am
I wrote out an ocean script from my ADE-XL setup, and would like to load it to restore the states, specs etc. For some weird reason (nothing to do with Cadence but the design environment I have), the spec limits are not saved in the ADE-XL file. So I need to specify spec limits each time I open the ADE-XL view new.
When I write an ocean script, I can see that this info is there. So I thought I might be able to bypass the problem by writing and reading an ocean script. However, I only see an option for saving the ocean script, but none for reading it it.
Any tips?
Vivek
Riad KACED
Swindon, UK
Re: Cadence ADE-XL: loading a previously saved ocean script
Reply #1 - Dec 7th, 2009, 12:18am
I think the same question has been asked in:
http://www.cadence.com/Community/forums/p/14171/23571.aspx#23571
Riad.
Riad KACED
PDK, EDA Support Engineer.
