Aug 15th, 2024, 1:22pm
the differential amp CM sweep (Read 2549 times)
ericX
Dec 10th, 2009, 12:18am
Hi,I'm new here.
I simulate the differential amp, when I connect the substrate of the M1 and M2  to the source terminal,there comes a strange current at the tail current source M3 when the input is 0,and until reaching the saturation region is  the sum of the two mosfet  equal to the tail current.But if I connect the substrate to the ground, everything turns normal.I don't know why, so I come here asking for help.Thank you! The *.sp file is as follow:
.lib 'cmos90.sp' tt
*the lib is the 90nm cmos lib from UCB
m1 out1 in pp pp nmos l=1u w=2u
m2 out2 in pp pp nmos l=1u w=2u
m3 pp bb gnd gnd nmos l=1u w=4u
rd1 dd out1 10k
rd2 dd out2 10k
vdd dd gnd dc 3
vbb bb gnd dc 0.6
vin in gnd
.op
.dc vin 0 3 10m
.print  lx4(m1) lx4(m3) par("lx4(m1)+lx4(m2)")
.end
Mayank
Re: the differential amp CM sweep
Reply #1 - Dec 10th, 2009, 12:22am
    Prefix a line .connect gnd 0 to your spice netlist...I think that should solve the problem....There's no node 0 in your ckt....
--mayank.
ericX
Reply #2 - Dec 10th, 2009, 12:34am
It doesn't work...I don't think it is the ground that causes the problem...
