vivkr
I wrote out an ocean script from my ADE-XL setup, and would like to load it to restore the states, specs etc. For some weird reason (nothing to do with Cadence but the design environment I have), the spec limits are not saved in the ADE-XL file. So I need to specify spec limits each time I open the ADE-XL view new.
When I write an ocean script, I can see that this info is there. So I thought I might be able to bypass the problem by writing and reading an ocean script. However, I only see an option for saving the ocean script, but none for reading it it.
Any tips?
Vivek
