Jul 18th, 2024, 4:26am
cds_iprobe function (Read 3794 times)
filipe
Brasil
cds_iprobe function
Dec 02nd, 2009, 11:09am
Related to the $cds_iprobe function used at verilogams to probe a current pin, the correct syntax is:
I(x) <+ $cds_iprobe("top.middle.pin");
How can I use the cds_iprobe function with the hierarchy path as a variable into the function???
Filipe
View Profile filipe filipe   IP Logged
aymelis
Re: cds_iprobe function
Reply #1 - Mar 13th, 2012, 8:10am
hi filipe,
Did you find a solution to pass the hierarchy via a variable ?
Thanks and regards
