Aug 15th, 2024, 7:21pm
Dependency of inductor value in a CS LNA (Read 3565 times)
A Kumar R
India
Dec 03rd, 2009, 6:32am
hi, all
while reading a paper on a multi-band lna design, i came across this sentence...
"in short channel MOSFET the value of the inductor( which will be present at the source of MOS device in CS configuration) is almost independent of the bias current and device width, where as, in long channel it depends on  bias current and device width"
can anybody explain how this value of inductor varies in accordance with channel length?
Re: Dependency of inductor value in a CS LNA
Reply #1 - Dec 3rd, 2009, 5:47pm
It doesn't.
They are hinting at the fact that the capacitance changes at the input of the transistor(C looking into the gate)
If C changes then the need for a different L become evident.
aaron_do
Reply #2 - Dec 3rd, 2009, 6:54pm
I believe they are talking about the degeneration inductor, Ls, in an inductive degeneration LNA. Ls is chosen to be equal to RsourceT where Rsource is usually 50 ohm. I'm not sure why they say it is independent of biasing and device width for a short-channel device however.
For long-channel, ωT = μn(VGS-VTH)/L2 [Razavi, Design of Analog CMOS Integrated Circuits, ch2, pp. 40] so if anything, the choice of Ls should be independent of the bias current and device width for a long-channel device...unless i've misunderstood something...
cheers,
Aaron
Mohamed.eissa
Reply #3 - Dec 10th, 2009, 11:33am
Hello
It will be help full if you can send me this paper or where can i get it, but what I know about that is:
Ls=( Rs/wt)=(Rs*Cgs/gm) = Rs*(Cgs*L/μCox*W*Veff)
if we assumed that Cgs=Cox*W*factor
so Ls = Rs*(factor*L/μ*Veff)
so I guess it depend on the Veff so changing the Width and current by same value keeping Veff constant will mean the Ls value need not be changed,
But any change in Veff or L will lead to a need in Ls change for optimization.
But about short channel and long channel effect on these relations I am not sure about that I have to check it.
A Kumar R
India
Reply #4 - Dec 11th, 2009, 1:12am
hello mohamed..
i have attached the corresponding paper. it is section 4 of that paper.please find it.
Quote:
I have deleted the attached paper. Please only attach papers that you personally own the copyright to.
The paper was ...
IEEE TRANSACTIONS ON MICROWAVE THEORY AND TECHNIQUES, VOL. 50, NO. 1, JANUARY 2002;
Concurrent Multiband Low-Noise Amplifiers—Theory, Design,and Applications;
Hossein Hashemi and Ali Hajimiri
-Ken Kundert
« Last Edit: Dec 11th, 2009, 5:21pm by Ken Kundert »
yvkrishna
Reply #5 - Jan 19th, 2010, 11:03pm
