Sep 27th, 2024, 11:13pm
MOSFET Cap biasing (Read 1692 times)
AnalogDE
MOSFET Cap biasing
Dec 04th, 2009, 9:54am
I am using some PMOS MOS caps in my comparator design which are used for offset cancellation (MIM caps not available in my process).  I am biasing the caps in inversion region, but because of supply/headroom constraints the bias can be at the worst case around vtp or a little less.
Can I compensate for the risk of getting less capacitance by adding option caps to increase the effective area of the cap, or must I ensure my biasing has > vtp across the MOS cap?
rf-design
Reiner Franke
Re: MOSFET Cap biasing
Reply #1 - Dec 14th, 2009, 7:50pm
If the number of circuits blocks is small possible needing MIM-cap and your specification could be implemented with MOS-caps you should stay with MOS-cap.
Typical you should design both circuit options with a possible different dimensioning. The you could compare and decide.
MOS-caps are restricted in voltage range related to supply for a given nonlinearity. The second drawback is that the only one electrode is free. The bottom electrode can have 30% parasitic capacitance. So that limit the range of circuit topologies. But for offset correction storage I think it is useable.
