Aug 16th, 2024, 10:08am
odd behavior with trasition filter in Verilog-A / HSPICE (Read 2312 times)
bobr
Dec 07th, 2009, 9:15pm
When I use the transition filter to model a digital signal, it works nicely - as long as I use zero delay. If I put a non-zero number into the optional delay argument, the filter delays the transitions, but then completely ignores the options for rise and fall times. It appears that rise/fall time become shortened to one or two simulator steps, if delay is specified. Here is how I use it:
  V(q)  <+ transition( state ? vhi : vlo, 0, trise, tfall);
  V(qb) <+ transition( state ? vhi : vlo, delta_t, trise, tfall);
The output of q rises and falls as specified, but the output of qb does not. Is this possibly a bug in HSPICE, or am I missing something?
Thanks, Bob
FYI, I'm using HSPICE version: C-2009.09 64-BIT
and Verilog-A Compiler Version 1.83.100.080509
patrick
Santa Rosa, CA.
Re: odd behavior with trasition filter in Verilog-A / HSPICE
Reply #1 - Dec 25th, 2009, 1:18pm
Hi Bob,
Can you provide the rest of the module and a simple netlist? then we can take a look. HSPICE should control the timestep to maintain the specified rise/fall times properly when a delay is used.
Patrick
Ari
Israel
Reply #2 - Jan 19th, 2010, 5:44am
Bob,
I faced the very same bug with hSpice64 2009.09. Going back to 2009.03 resolved this issue.
I am working with Synopsys AE on creating test-case for this bug, and therefore would like to more information about the netlist in which this bug occured. Please contact me.
Ari
