Jul 17th, 2024, 6:33am
Setting voltage in "static" analysis, in keeping it in transient analysis (Read 1954 times)
Ari
Israel
Jan 18th, 2010, 1:37pm
I have VGA (Variable Gain Amp.) which I would like to automatically tune to get specific gain across all corners and conditions.
The gain control voltage vctrl should be set during the operating point analysis ("static" analysis) and later on it should not change during transient simulation.
Yet, the following pice of code does not work, as during O.P. and transient 0s time vctrl value is fine, but right after 0s time it drops to 0s (treats vctrl as a relay)
   if (analysis("static"))
    V(vctrl) : V(vga_outp,vga_outn) ==EXPECTED_GAIN*(V(vga_inp,vga_inn));
How can I get the behavior I need, i.e. have vctrl computed during O.P. and keeping this value throughout transient simulation ?
Ari
Re: Setting voltage in "static" analysis, in keeping it in transient analysis
Reply #1 - Jan 19th, 2010, 1:20am
Because you only have the contribution present during the "static" analysis - i.e. it's only there when the if is active. You need the contribution present all the time - effectively you have a switch branch (I believe) - it's a bit hard to tell without seeing the rest of your model.
Ari
Israel
Reply #2 - Jan 19th, 2010, 5:40am
Andrew,
Thank you for your reply.
I found the following solution:
real vctrl_real;
analog begin
 if (analysis("static")) begin
    V(vctrl) : V(vga_outp,vga_outn) == EXPECTED_GAIN*V(vga_inp,vga_inn);
     vctrl_real=V(vctrl);
    else
      V(vctrl) <+ vctrl_real;
I'll be happy to know if there are other possible solutions for this.
Ari
