Jul 17th, 2024, 6:14am
Import VHDL test bench in Virtuoso AMS (Read 4599 times)
fran2k5
Dec 23rd, 2009, 5:55am
I would appreciate your feedback on the following issue.
We would like to verify a MS chip in Virtuoso AMS.
The digital part has been developed by using VHDL test benches.
Is it possible to import such test benches in Virtuoso AMS?
Best regards,
frank
Re: Import VHDL test bench in Virtuoso AMS
Reply #1 - Jan 6th, 2010, 10:19am
Absolutely. The simulator itself would have no problem with this. But it's unclear what you mean by "import". You could create a VHDL view, with the testbench code, and then create a symbol for it and wire it up to the DUT - it's really hard to tell without knowing precisely how you have things structured.
Or you could simulate the code from the command line?
Unfortunately the more I type here, the less I think I'm helping Wink
The issue is that without knowing precisely what you're trying to achieve, and how the testbenches are structured, it's very hard to give a precise answer (see the Forum guidelines and Ken's post http://www.designers-guide.org/Forum/YaBB.pl?num=1252743617
fran2k5
Reply #2 - Jan 13th, 2010, 12:48pm
Thank you Andrew for your reply.
I've recently discovered the existence of the Spice-VHDL flow that allows the simulation of MS systems by using test-benches developed in VHDL.
This flow is based on the use of tools like SimVision typically used in the digital design flow. I was wondering if it would be possible to perform the same simulations in the Cadence AMS environment by importing somehow the VHDL test-benches.
Best regards,
frank
Reply #3 - Jan 16th, 2010, 8:07am
What SPICE-VHDL flow are you talking about?
As I said, doing all this with the Cadence AMS Designer simulator will be no problem; I just don't know what you mean by "import", as I said before. Your response didn't really provide any more clarification... (sorry!)
