When I use the transition filter to model a digital signal, it works nicely - as long as I use zero delay. If I put a non-zero number into the optional delay argument, the filter delays the transitions, but then completely ignores the options for rise and fall times. It appears that rise/fall time become shortened to one or two simulator steps, if delay is specified. Here is how I use it:
Code: V(q) <+ transition( state ? vhi : vlo, 0, trise, tfall);
V(qb) <+ transition( state ? vhi : vlo, delta_t, trise, tfall);
The output of q rises and falls as specified, but the output of qb does not. Is this possibly a bug in HSPICE, or am I missing something?
Thanks, Bob
FYI, I'm using HSPICE version: C-2009.09 64-BIT
and Verilog-A Compiler Version 1.83.100.080509
