Sep 28th, 2024, 3:22am
[help] dc offset cancellation techniques (Read 6578 times)
trashbox
Dec 08th, 2009, 2:14am
As attachment, the class-AB driver output is audio signal (20~20KHz) and has 1~10mV DC offset. Is there any method or close-loop DC offset cancellation circuit to eliminated it(spec. require  the dc offset <2mV)? Can the so-called servo circuit solve this problem in this case? Thanks in advance.
duncandu
Re: [help] dc offset cancellation techniques
Reply #1 - Dec 8th, 2009, 1:40pm
Like auto-zero, or servo DAC, etc.
Many techniques on offset cancellation can be applied in this case.
trashbox
Reply #2 - Dec 8th, 2009, 5:56pm
Hi duncandu,
Thanks for your reply. Would you please offer me the servo DAC references?
Best regards
HdrChopper
Reply #3 - Dec 8th, 2009, 6:32pm
Hi Trashbox,
Check this thread for references on choppers for SE amplifiers...
http://www.designers-guide.org/Forum/YaBB.pl?num=1259664512
Best
Tosei
Keep it simple
RobG
Bozeman, MT
Reply #4 - Dec 14th, 2009, 5:05pm
I'm not sure why you are seeing such offset in simulation - are you sure it isn't a finite gain issue? At any rate, if you are using a process 0.5u or smaller you should easily be able to get the offset down by using larger devices. You probably want low 1/f anyway.  Chopping might also work well since the input frequency is low, and the ear is a great filter above 20kHz
