Greetings,
1) Before running a parasitic back-annotated simulation, you might
want to try running just an LPE, layout parameter extracted
simulation. That is, you extract just the devices and simulate.
--> This validate the layout is correct. You don't say much about
the implementation, but it maybe that the folding and merging
of devices has altered something.
--> Basically your parasitic back-annotated capacitance simulations
provide equivalent information so this appears to be done and
the issue is not in the basic implementation.
2) There are two things(at least
) to look for in with back with
back-annotated parasitics:
a) Are the biases correct?
If the bias currents are different than the performance will
be different. An easy test is the power dissipation the both
pre-layout and post-layout simulation results the same? After
that check each stage for bias. Then check the common mode
levels.
b) If the bias voltages and current are okay and the performance
is still off, then you need to look for other issues.
- Can you probe internally and look at the output of the first
stage? Are the results that same for both pre-layout and
post-layout
- Can you look at the gain of the second stage? Is the gain
correct? You don't specify the implementation in detail,
however, common-source amplifiers are sensitive to the
resistance between the source and the power supply since
this resistance can act like a degeneration resistor.
- Can you look at the common-mode feedback amplifier?
If it is not working properly the common-mode level may
end up outside the optimum operating range?
---> You need to localize the issue, if possible. Localizing the issue
can be difficult because everything is connected
3) Are you using ADE [IC5141/IC61] for your simulation environment?
ADE has the option to back-annotate selected nets and simulate
so you may be able to localize the issue?
4) Are you using ADE [IC61], using the Parasitic Aware Design flow,
you can do sensitivity analysis to identify the relationship between
specific parasitics and the dc gain.
5) You also mention a zero in the ac response. How is your
compensation implemented? Is it possible that the zero
is due to layout parasitic resistance in the routing for the
comp cap? Or does the extracted capacitor include the
extracted resistance of the plate? How was the compensation
capacitor implemented, MOS CAP [MOS transistor]?
