Sep 28th, 2024, 8:17am
dummy poly resistance (Read 2316 times)
Dipankar
Dec 11th, 2009, 6:23am
Dear All,
             Need to put dummy resistors around the regular ones . I am using rppolywo. Should it be connected to VDD or gnd ?  I think rppolywo should be connected to VDD (rnploy should have benn connected to ground) still not sure. Can somebody throw some insights ?
With Thanks and Regards,
Dipankar.
HdrChopper
Re: dummy poly resistance
Reply #1 - Dec 12th, 2009, 10:30am
Hi Dipankar,
I do not see a problem of connecting them to either potential since there are no junctions involved that you need to reverse bias.
I usually connect them to one of nodes from the active resistor string.
Cheers
Tosei
Keep it simple
Reply #2 - Dec 13th, 2009, 4:27pm
as a general practice I would suggest grounding it out. Never leave anything floating in my opinion.
