Aug 17th, 2024, 5:15am
Experience on design and simulation of class-d audio power amplifiers? (Read 1948 times)
weber8722
Dec 14th, 2009, 7:55am
has anybody experience on the design and performance simulation (distortion, frequency response, stability, noise) of class-d audio power amplifiers? E.g. on hysterisis-based self-oscillating circuits vs classical pwm-based systems?
I wonder also if transient simulation is an effective method due to large simulation times and limited accuracy. I tried steady-state methods but the results are not meaningful.  I wonder if pss/qpss can be applied as succesful as in RF applications? Undecided
Bye Stephan
Re: Experience on design and simulation of class-d audio power amplifiers?
Reply #1 - Dec 14th, 2009, 8:07am
weber8722 wrote on Dec 14th, 2009, 7:55am:
PSS/QPSS is Steady State Analysis.
What do you mean by "steady-state methods" ?
I think PSS/QPSS is useful for Class-D amplifier simulation. But it is fairly limited regarding applicable sutuations.
I'm not so familiar with audio applications.
But my colleagues who are engaged in audio applications use Transient Analysis with Transient Noise Ability by following simulator.
BDA's Analog FastSPICE.
http://www.berkeley-da.com/prod/oview.htm
