Sep 18th, 2024, 11:45am
Pages: 1 2
poly orientation in lay-out (Read 2894 times)
Mayank
Re: poly orientation in lay-out
Reply #15 - Feb 02nd, 2010, 6:26am
Hi Berti,
      Quote:
But for advanced  processes (45nm and below) quite different transistor behavior (±20%) has been reported depending on the transistor orientation (related to the orientation of the crystal lattice of substrate).
    Generally 111 lattice orientation is considered the best substrate orientation to align the transistor channel. The stress and atom density is least along this direction, hence increased mobility.
    I think we just need to align transistor directions in layout. Fabricator himself takes care to fab it in that alignment.
Mayank.
Berti
Reply #16 - Feb 2nd, 2010, 7:04am
Hi Mayank
I think in most recent technologies people switched to <100> ...
Sure, but in a typical SoC not all the transistors have the same orientation?
Should that design practice be reconsidered for <65nm or do DRC/DFM not even allow different poly orientations?
Cheers
Pages: 1 2
