Absolutely. The simulator itself would have no problem with this. But it's unclear what you mean by "import". You could create a VHDL view, with the testbench code, and then create a symbol for it and wire it up to the DUT - it's really hard to tell without knowing precisely how you have things structured.
Or you could simulate the code from the command line?
Unfortunately the more I type here, the less I think I'm helping
![Wink Wink](https://designers-guide.org/forum/Templates/Forum/default/wink.gif)
The issue is that without knowing precisely what you're trying to achieve, and how the testbenches are structured, it's very hard to give a precise answer (see the Forum guidelines and Ken's post
http://www.designers-guide.org/Forum/YaBB.pl?num=1252743617Regards,
