Aug 16th, 2024, 3:15am
Help with a stability problem (Read 6100 times)
refugee
Jan 04th, 2010, 5:37pm
I want to ask if the buffer in the loop will affect the close loop phase margin.
If yes, how does it affect the close loop phase margin. (by 90 degree?)
Thanks for your kindness help
Mayank
Re: Help with a stability problem
Reply #1 - Jan 4th, 2010, 8:42pm
     Anything in the signal path that has poles and zeroes will affect the phase margin...Why dont you just replace the buffer with it's Transfer Function and compute Phase margin from Overall Open Loop  Transfer Function...which in your case is dependent only on Opamp Gain Response.
Mayank.
buddypoor
Bremen, Germany
Reply #2 - Jan 5th, 2010, 1:19am
sorry, but the whole circuit looks a bit "uncommon".
If you apply 100% negative feedback to a stage with a gain of "1" you get an overall gain of 0.5.    Is this your intention???
rajdeep
UK
Reply #3 - Jan 5th, 2010, 2:48am
If I consider an ideal unity gain buffer (having infinite BW), then it  can be said that loop gain of the overall ckt is always 0 DB, and the phase margin (of the loop gain) is 180deg!!!
If I consider a real unity gain buffer then the above statements remain true upto the BW of the unity gain buffer. Isnt it??
Also, why are you concerned abt the closed loop phase margin, when in the feedback path you have a direct connection i.e. no extra poles and zeros in the feedback path?
cheers!
Rajdeep
refugee
Reply #4 - Jan 7th, 2010, 5:55am
Mayank wrote on Jan 4th, 2010, 8:42pm:
Mayank.
thank you,  mayank. I think I got your idea
refugee
Reply #5 - Jan 7th, 2010, 6:02am
buddypoor wrote on Jan 5th, 2010, 1:19am:
sorry for the simplified diagram.  there are some extra gm block in the forward path. in fact, the output is a large power device. so i need a buffer to drive it
buddypoor
Bremen, Germany
Reply #6 - Jan 7th, 2010, 6:02am
refugee wrote on Jan 7th, 2010, 5:55am:
Mayank.
Yes, everything which was said about the stability of the circuit is OK.
But, REFUGEE, did you realize that the overall gain is - 6dB ??
Is this really your intention?
Reply #7 - Jan 7th, 2010, 7:58am
Its a simplified conceptual drawing.
Loosen up!
buddypoor
Bremen, Germany
Reply #8 - Jan 7th, 2010, 8:33am
loose-electron wrote on Jan 7th, 2010, 7:58am:
Loosen up!
In this case, I would say: It is dangerous and of no value to speak about stability of a system which is given only as a "simplified conceptual" drawing. Don`t you agree?
Reply #9 - Jan 8th, 2010, 1:28pm
How about - "Could you please provide a drawing that shows some more detail of what you are trying to do?"
buddypoor wrote on Jan 7th, 2010, 8:33am:
Loosen up!
