refugee wrote on Jan 7th, 2010, 5:55am:Mayank wrote on Jan 4th, 2010, 8:42pm:Hi,
Anything in the signal path that has poles and zeroes will affect the phase margin...Why dont you just replace the buffer with it's Transfer Function and compute Phase margin from Overall Open Loop Transfer Function...which in your case is dependent only on Opamp Gain Response.
Mayank.
thank you, mayank. I think I got your idea
Yes, everything which was said about the stability of the circuit is OK.
But, REFUGEE, did you realize that the overall gain is - 6dB ??
Is this really your intention?
