Aug 15th, 2024, 9:18pm
very strange problem need help, pls (Read 5498 times)
lhlbluesky_lhl
Jan 07th, 2010, 4:38am
have designed a SH(sample-holde) circuit, just as the picture shows (fig1). it consisits of four TG and two Buffer, IN is a changing signal, first, S1 is on, and IN is stored in C1 (just called IN1), then, S2 is on, IN (has changed) is stored in C2 (IN2). after a while, S3,S4 on at the same time, readout the difference of IN1 and IN2 (fig2). that is, S3 and S4 are the same signal.
originally, i use S3 and S4 for different ports in layout, and i add stimilus in the four ports, of course, S3 and S4 have the same stimilus, S3- and S4- have the same stimilus, and the simulation result is ok (12 bit resolution). while i want to connect S3 and s4, S3- and S4- together separately in layout, so only two ports needed. however, when rerun the simulation, the result is very bad, very different, only 8 bit resolution.
i'm sure that, i only connect them together in layout with a short wire (fig3), nothing else. but why? why does the resolution have such a big reduction? i cheched my layout, except the two connecting wire, no other change has made. but the simulation result is very strange, can any one help me? thanks all.
in fig3, only two stimilus added, one for S3(S4), one for S3-(S4-). i really need your help, thanks.
and after i connect S3 and S4, S3- and S4-, the simulation result shows that, the resolution decline starts at the node after the first switch (that is, the positive end of buffer), but i have not changed that part, i only added the two short wire as fig3 shows. it is very strange, why?
lhlbluesky_lhl
Re: very strange problem need help, pls
Reply #1 - Jan 8th, 2010, 6:34am
can anyone help me? thanks all.
Reply #2 - Jan 8th, 2010, 1:25pm
can you attach a jpg or png type picture please? The winzip file did not open for me.
Mayank
Reply #3 - Jan 8th, 2010, 8:10pm
Hi bluesky,
                 Seems like opamp misfunctioning on connecting S3 & S4 / S3- & S4- .....Maybe, when you are connecting the gates of two TG's , the Cgs  & Cgd caps at the opamp o/p node get added. This in turn might  cause some foul play with your opamp's freq. response like decrease your opamp BW etc. Check if this is happening ?  Run it again at schematic level with parasitic + interconnect caps included at these nodes.....If error shows up there, means it's not a layout issue after all.
Mayank.
lhlbluesky_lhl
Reply #4 - Jan 10th, 2010, 5:47am
i checked the opamp, and it can work well when i connect S3,S4 and S3-,S4- together. are there any other reasons?
the following is the picture.
Mayank
Reply #5 - Jan 10th, 2010, 9:08pm
Hi bluesky,
                 Does it work fine in schematic after connecting S3 & S4 / S3- & S4- ?? Atleast that would clear out whether it's a layout issue or a schematic one....
lhlbluesky_lhl
Reply #6 - Jan 11th, 2010, 3:54am
it works fine in schematic after connecting S3 & S4 / S3- & S4-, so i think it is a layout issue. but i don't which parasitic cap or res causes this problem. pls help me. thanks.
Mayank
Reply #7 - Jan 11th, 2010, 5:36am
Hi bluesky,
                Well our differential says --1. schematic works fine
                                                           2.  opamps are responding correctly with parasitic caps too both in layout and schematic...
I hope your LVS is correct....
Can you pls. attach you output waveforms with and without S3/S4 connections ??
Mayank.
lhlbluesky_lhl
Reply #8 - Jan 12th, 2010, 4:37am
the output waveform is just the same, except that (for the same input)the resolution in the positive end of opamp has a big reduction. why? any possible reasons?
