Aug 15th, 2024, 3:58am
PAC simulation is wrong (Read 3925 times)
lunren
Asia
Jan 14th, 2010, 2:15pm
Hi All,
I tried to use PSS+PAC simulate a very simple SC circuit (please refer to the attached Picture1). First, the two equal caps are charged to 1.8V and 0.8V, then open the charge switches and then close the middle switch so that the two caps share the chargers and reach the same voltage. Principly, the voltage of sigB increase by 0.5V and the voltage of rstB decreases by 0.5V.  The PSS steady state solution is correct (please refer to the attached Picture2).
However, the PAC results are not correct (please refer to second picture). The clock is about 4.6Mhz. From PAC, the changes of sigB and rstB are halved (only 0.25V).  Picture 3 shows PAC results. Anyone can try this circuit.
I was confused by the PAC results. Can anyone give me some hint what was going on?
Lunren
Lunren
lunren
Asia
Re: PAC simulation is wrong
Reply #1 - Jan 14th, 2010, 2:16pm
Picture2 (PSS steady state)
Lunren
lunren
Asia
Reply #2 - Jan 14th, 2010, 2:17pm
Picture3 (PAC results)
Lunren
lunren
Asia
Reply #3 - Jan 14th, 2010, 4:40pm
Lunren
