Jul 18th, 2024, 10:19pm
Verilog A simulation in spectre (Read 9030 times)
AmiyaB
Kolkata
Jan 18th, 2010, 8:49pm
I have simulated the verilog-A code for and-gate using spectre simulator.
I have stopped the simulator using the statement : kill USR2 <PID>  from terminal.
I got the saved state file (*.srf).
When I started the simulation again from the same point (where i have stopped) using the spectre recover statement, it is showing that the simulation is running.
# spectre +lqt 0 tb.scs +recover=tb_recov.srf_10us
But the results are not correct.
The code for AND gate and its test bench, what i have used are given below.
Can You tell how  to re-simulate it properly.
AND gate code
`include "constants.vams"
`include "disciplines.vams"
module andgate (y, a, b, vdd, gnd);
input a, b;
output y;
inout vdd, gnd;
electrical a, b, y, vdd, gnd;
parameter real tr = 10f, tf = 10f, td = 10f;
real y_val, vd, gn, vt;
integer logic1, logic2;
analog begin
     vt = 0.5 * V(vdd);
     vd = V(vdd);
     gn = V(gnd);
     logic1 = (V(a) >= vt);
     logic2 = (V(b) >= vt);
     y_val = (logic1 && logic2) ? vd : gn;
     V(y) <+ transition(y_val, td, tr, tf);
Test bench
V1 (VSS 0) vsource dc=0 type=dc
V0 (VDD 0) vsource dc=1.8 type=dc
I0 (Y VDD B VDD VSS) andgate
Re: Verilog A simulation in spectre
Reply #1 - Jan 19th, 2010, 1:29am
I presume that isn't your entire testbench? No signals are changing, so there wouldn't be much point doing a long transient, and the B input appears to be floating. Also, there's no analysis statements in there, so I can't see what you're actually simulating.
Please give the whole story, not just part of it. And please explain what is "not correct" about the results (maybe a plot to illustrate it?).
It would also be useful to know what version of spectre you're using.
AmiyaB
Kolkata
Reply #2 - Jan 19th, 2010, 2:20am
The full test bench  goes like below :
simulator lang = spectre
//--Netlist--
include "/local_admin_2/amiya/sim/Verilog_A_Lib/tb_andgate//netlist.scs"
//--tran Analysis Setup--
     tran tran
+      start=0
+      stop=2e-08
+      outputstart=0
+      step=1e-10
+      errpreset=conservative
+      savetime=[5n 10n 15n 20n]
//--Simulator Setup--
sim_options options
+      reltol=0.001
+      vabstol=1e-06
+      iabstol=1e-12
+      tnom=27
+      scalem=1.0
+      scale=1.0
+      gmin=1e-12
+      rforce=1
+      maxnotes=5
+      maxwarns=5
+      digits=5
+      cols=80
+      pivrel=0.001
+      ckptclock=1800
+      temp=27
dcInfo info what=oppoint where=rawfile
CapInfo info what=captab where=rawfile detail=node
//--Voltages to be Saved--
opt1 options save = all
And the netlist as below :
// Generated for: spectre
// Generated on: Jan 17 14:14:34 2010
// Design library name: Verilog_A_Lib
// Design cell name: tb_andgate
simulator lang=spectre
global 0
ahdl_include "/proj/NMDT_PMDC/PLL/Project/PLL_UMC/Database/schematic/Verilog_A_Lib/andgate/ve
riloga/veriloga.va"
// Library name: Verilog_A_Lib
// Cell name: tb_andgate
V3 (B 0) vsource type=pulse val0=0.0 val1=1.8 period=2n delay=100f rise=5p \
       fall=5p width=995p
V4 (C 0) vsource type=pulse val0=0.0 val1=1.8 period=7n delay=100f \
       rise=50p fall=50p width=3.1n
I2 (net14 Y C VDD VSS) andgate
Here, i have one input as VDD and other is a Pulse signal.
I have simulated from 0 to 20ns, where the result Y is as expected, same as input B.
I haved saved the state of simulation at the end of simulation at 20ns. The file name is of extension *.srf
Now I restarted the simulation from 20ns to 40ns, using the same netlist  and testbench and the .srf file as recover file using the statement:
spectre +lqt 0 tb.scs +recover=tb.scs.tran.srf_20ns
where tb.scs.tran.srf_20ns is the saved .srf file.
I changed the transient analysis statement as :
     tran tran
+      start=0
+      stop=4e-08
+      outputstart=0
+      step=1e-10
+      savetime=[5n 10n 15n 20n 30n 40n]
The simulation output Y from 20ns to 40ns is coming zero, which should follow input B as other input is VDD.
Reply #3 - Jan 19th, 2010, 6:15am
I just ran your testcase in spectre 7.1.1.275.isr17, and attached is the result I get from the second run (using +recover).
Look OK to me...
As I asked before, what version of spectre are you using? (this will be in the output of spectre).
AmiyaB
Kolkata
Reply #4 - Jan 19th, 2010, 8:28pm
Hi Andrew,
Thank You for your quick reply.
I am using Spectre Version 6.2.0
I will try in the new version.
Amiya
