Jul 16th, 2024, 9:24am
BDA SIM Transient save-restart (Read 3550 times)
Mayank
Jan 21st, 2010, 9:08pm
     Spectre supports save-restart in transient analysis by saving states at specified times....
    Does BDA AFS (or BDASIM ) support it ??
    I am simulating a big ckt in bdasim & want to save state files so that i can resume transient in case of an error...
    Also, Do bdasim 32 bit version gives problems with simulating big ckts ?
Mayank.
David Lee
Re: BDA SIM Transient save-restart
Reply #1 - Jan 21st, 2010, 11:46pm
Hi Mayank,
BDA's Analog FastSpice saves its state automatically so that you can restart the simulation if needed. If you need more help with this, I suggest that please get in touch with your AE.
If your big circuit requires less than 2-3GB of RAM, 32 bit AFS should run just fine. If more than that, please run 64 bit AFS.
David.
- David
