David Lee
Hi Mayank,
BDA's Analog FastSpice saves its state automatically so that you can restart the simulation if needed. If you need more help with this, I suggest that please get in touch with your AE.
If your big circuit requires less than 2-3GB of RAM, 32 bit AFS should run just fine. If more than that, please run 64 bit AFS.
David.
