Jul 19th, 2024, 2:34am
supply noise (Read 2615 times)
sure
supply noise
Jan 31st, 2010, 10:07pm
hi,
  i am designing charge pump in pll, so in that how to apply supply noise. I heard through some one that supply noise has white PSD, is it true?
sure.
Re: supply noise
Reply #1 - Feb 1st, 2010, 6:03pm
very dependent on what else is connected to the supply, because it creates the noise.
raja.cedt
Re: supply noise
Reply #2 - Feb 1st, 2010, 7:43pm
hi sure,
          as loose electron said it is very depends on how other's are working manily  on what freuqency digital end works and how good your power grid. But i think supply noise not that random as you said it is having white psd...up to my knowledge it's quite deterministic (i saw one kind of psd for 4.8GBPS serial link..there it is having some peaks rather flat). May be some exp person can give more abut how a typical supply noise specturm.
Rajasekhar.
Mayank
Re: supply noise
Reply #3 - Feb 1st, 2010, 8:47pm
Hi sure,
          Supply noise is rarely white.....
It does have a broadband noise floor like any other noise, which can be called white....
but depending on your Mixed Signal cktry, you are bound to observe some peaks.
Also the PMU is a known source for supply noise spurs owing to PWM pulses used inside.
Exact derivation of supply noise profile can only be obtained by full chip simulation.
Mayank.
raja.cedt
Re: supply noise
Reply #4 - Feb 2nd, 2010, 3:46am
hi,
  probably this paper may help ...
http://www-vlsi.stanford.edu/papers/ea_jssc_05.pdf
rajasekhar.
love_analog
Re: supply noise
Reply #5 - Apr 7th, 2010, 2:27pm
why are you planning to apply supply noise to CP.
In a typical PLL, its the VCO (and also the post VCO buffer) which will cause the most supply induced jitter on the output.
If you just want to get a feel, apply a sinewave at a frequency which is a non-integer of the reference clock but I suspect you need to answer the why question first.
loveanalog.blogspot.com
The Power of Analog
