Mayank
Hi sure, Supply noise is rarely white..... It does have a broadband noise floor like any other noise, which can be called white.... but depending on your Mixed Signal cktry, you are bound to observe some peaks. Also the PMU is a known source for supply noise spurs owing to PWM pulses used inside. Exact derivation of supply noise profile can only be obtained by full chip simulation. -- Mayank.
