neoflash wrote on Feb 2nd, 2010, 6:26am:Time domain result means pulse response and PRBS output response of the transmission line.
If I use touchstone output model, the prbs response is fairly close.
What is it close to ?
Is there any reference ?
neoflash wrote on Feb 2nd, 2010, 6:26am:If I use W element, the prbs response is very different and has much less loss.
What do you compare with ?
Again describe correctly.I guess followings.
- You have some reference as correct results.
- Results of transient analysis using s4p(4 ports s-parameters) from Q3D are cosistent with reference results.
- But results of transient analysis using W-element from Q3D are not consistent with reference results.
My guesses are correct ?
If so, Q3D itself is correct.
Your settings for dumping W-element model file from Q3D are wrong.
Upload your netlist of HSPICE, s4p file and model-file for W-element.
