Feb 11th, 2026, 4:08pm
Ansoft Q3D 2D solver result mismatch (Read 1956 times)
neoflash
Mixed-Signal
Designer
Feb 01st, 2010, 8:18pm
I have encountered an issue of using Ansoft Q3D's 2D solver.
The problem is that I have one demo FR4 trace's geometric information and w-element model extracted by vendor. I was redoing the modeling in Q3D.
I can have exactly same sdd21 result. However, the time domain result is very different and I'm sure my own result is incorrect.
If I export hspice w element table model, the result is very different. If I use touchstone model, the result is very close.
I have no idea what is wrong with the exported w model? Any suggestion?
Re: Ansoft Q3D 2D solver result mismatch
Reply #1 - Feb 2nd, 2010, 1:51am
Please describe correctly so that eveyone can understand.
neoflash wrote on Feb 1st, 2010, 8:18pm:
What do you mean by "the time domain result" ?
What do you compare with ?
neoflash
Mixed-Signal
Designer
Reply #2 - Feb 2nd, 2010, 6:26am
Time domain result means pulse response and PRBS output response of the transmission line.
If I use touchstone output model, the prbs response is fairly close.
If I use W element, the prbs response is very different and has much less loss.
Reply #3 - Feb 2nd, 2010, 6:37am
neoflash wrote on Feb 2nd, 2010, 6:26am:
What is it close to ?
Is there any reference ?
Again describe correctly.
I guess followings.
 - You have some reference as correct results.
 - Results of transient analysis using s4p(4 ports s-parameters) from Q3D are cosistent with reference results.
 - But results of transient analysis using W-element from Q3D are not consistent with reference results.
My guesses are correct ?
If so, Q3D itself is correct.
Your settings for dumping W-element model file from Q3D are wrong.
Upload your netlist of HSPICE, s4p file and model-file for W-element.
« Last Edit: Feb 2nd, 2010, 7:45am by pancho_hideboo »
neoflash
Mixed-Signal
Designer
Reply #4 - Feb 2nd, 2010, 9:54am
pancho_hideboo wrote on Feb 2nd, 2010, 6:37am:
I guess followings.
Your guess is correct. I agree that Q3D is generating consistent result with the reference. However, the dumped w model has problem.
I'm also looking into the model file dumped. One problem I see is that the C matrix doesn't change much with increased frequency. If I replace the C matrix with the one in the reference design, the transient result is much closer to the reference.
neoflash
Mixed-Signal
Designer
Reply #5 - Feb 2nd, 2010, 9:56am
Actually, I almost see no setting for the w-element export operation.
I just right click the analyze menu, and chose "export circuit". Then in the output file selection chose hspice w element format. And click export. Am I missing any option setting?
Thanks for your inputs.
neoflash
Mixed-Signal
Designer
Reply #6 - Feb 2nd, 2010, 5:17pm
Exported W element based on table data.
