Carl F
Thanks for good comments,
If I've understood right, the reason that this may be a class AB stage is that the PMOS current of one output is a copy of the NMOS current of the other output. And, moreover, the peak output current can be order(s) of magnitude larger than the quiescent current set by the two output-stage current sources.
About CM control, I guess there are several ways to introduce that. But one issue in a fully-differential output stage is that the CM voltage INTO it should excite CM current OUT of it, which would not be the case if the first current mirror in the output stage is removed. But I'm sure there may be other (better?) ways to introduce CM output control than to connect the CM-regulator output to the diff-input-stage bias-current generator.
There may be a recovery time after one output PMOS (and the other output's NMOS) has been fully turned off, i.e., after returning from a large class-B output-current excitation. I suppose this schematic is a simplified one when it comes to such details, and therefore some minimum-bias current source needs to be added, as you say.
To set GBW, I had hoped that Cc could provide enough local feedback, on at least one output at a time (in class B operation), giving GBW=~Gm,diff/Cc. But that I've not yet checked how reliable it is also when it comes to manuf/temp spreads.
About literature, I've read quite a few papers in which many stages give very large gain spreads, e.g. depending strongly on the load impedance, and some of them don't even guarantee thermal stability inherently, depending on implementation technology (CMOS/Bipolar). But I just might haven't found the right papers yet maybe.
Again, thanks for pointing out several critical issues, and more comments are of course very welcome!
Carl F
