Jul 17th, 2024, 1:31am
can anyone recommend me a good NTF function for DSM? (Read 2011 times)
Lancelot
Feb 04th, 2010, 6:26am
Hi, guys,
I hope to design a CT DSM with OSR=8 to reduce the sampling frequency, and the ENOB should be above 12bits. originally, i want to adopt a 4 orders 4 bits architecture, and insert a zero inside the signal BW to improve the SNR. But it's not easy to choose a suitable NTF and the coefficients. can anyone give me some suggestions?
Berti
Re: can anyone recommend me a good NTF function for DSM?
Reply #1 - Feb 4th, 2010, 7:49am
Unless you know what you do I would recommend to use Richard Schreiers Delta-Sigma Toolbox to design the NTF and transform the result in a continuous-time filter.
By the way, I am not so sure whether minimizing the OSR is a good idea, unless it is required due to jitter requirements. By minimizing the OSR of a continuous-time modulator you loose an advantage over discrete-time modulators.
