Jul 19th, 2024, 4:15pm
Stripline to Microstrip transition using Multilayer Boards (Read 4948 times)
avins
Feb 08th, 2010, 10:51pm
My project is Strip line to Micro strip transition using multilayer circuit boards.
The paper from which I have got the project is attached.
This project is to be simulated using Ansoft HFSS v11.
I have visualized the project as show in on Pg.9 in the document.
Both the documents - my project word document and HFSS file is attached.
Avinash
Re: Stripline to Microstrip transition using Multilayer Boards
Reply #1 - Feb 9th, 2010, 5:47am
The following your post is completely same as this post.
http://www.designers-guide.org/Forum/YaBB.pl?num=1265698420
Don't do multiple post of same contents.
Reply #2 - Feb 9th, 2010, 5:34pm
and your question is?
avins
Reply #3 - Feb 9th, 2010, 10:04pm
The thing is can anyobe chek whether what I have visualised(design), Is it correct.I have attached the HFSS design.Actually, in the paper, it is given that ground plane has thickness of 17.5 micro metre.
I make a sheet cutout using polyline. I need to subtractground plane and polyline sheet, Here it gives an error, only If i make thickness of ground plane as 0mm, I am able to subtract properly.
Avin
avins
Reply #4 - Feb 9th, 2010, 10:06pm
The nasa technical paper is attached.
Avin
