avins
The thing is can anyobe chek whether what I have visualised(design), Is it correct.I have attached the HFSS design.Actually, in the paper, it is given that ground plane has thickness of 17.5 micro metre. I make a sheet cutout using polyline. I need to subtractground plane and polyline sheet, Here it gives an error, only If i make thickness of ground plane as 0mm, I am able to subtract properly.
Regards, Avin
