Aug 16th, 2024, 1:12pm
ROM acess in VerilogA (Read 6069 times)
hali
Feb 09th, 2010, 2:50am
Hi,I need help regarding ROM access in VerilogA cadence.I want to store a lookup table in ROM through VerilogA.I want to know how can i code this?or how to acess memory in verilogA? Undecided
Re: ROM access in VerilogA
Reply #1 - Feb 9th, 2010, 6:07am
hali wrote on Feb 9th, 2010, 2:50am:
What do you want to do ?
Do you want to use competely same ROM access in Verilog-D ?
If so, use Verilog-AMS.
If you simply want to use some table written by ascii code, use $table_model() in Verilog-A.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1239903838
« Last Edit: Feb 9th, 2010, 4:40pm by pancho_hideboo »
hali
Re: ROM acess in VerilogA
Reply #2 - Feb 9th, 2010, 12:39pm
Thanks for the reply.But actually i want to store a look up table of 8b10b coding in the rom.
Reply #3 - Feb 9th, 2010, 4:37pm
Do you understand Verilog-A, Verilog-D and Verilog-AMS ?
hali wrote on Feb 9th, 2010, 12:39pm:
Available variables are 32bit integer and 64bit real in Verilog-A.
Simply declare array of integer.
   "integer mem8b10b[0:9];"
You can write content of mem8b10b to file by "$strobe()".
You can read back content of file by "$table_model()".
hali
Reply #4 - Feb 11th, 2010, 1:29am
thank u so much.You reply helped me alot. Smiley
Reply #5 - Feb 11th, 2010, 2:05am
It seems that your application is RAM not ROM.
Both "$strobe()" and "$table_model()" are not needed.
« Last Edit: Feb 11th, 2010, 7:47am by pancho_hideboo »
