Quote:Because of single-ended conversion having a reference to ground,
How are you driving Differential Load with a Single-Ended circuit ? You using two identical circuits for driving diff. loads ?
Why dont you keep your circuit differential if your loads are diff. too ?
Why do you wanna trust your load to be exactly & precisely differential.
Practically, a headphone[or anything for that sake] cannot be precisely differential. What if the length of the wires differ by 1mm ?? or solder dots have different resistance ?
It's always better to keep your circuitry robust.
What is the major contributor to CM noise ?
it it because of degraded -ve PSR ??
Quote:5th order 1.5bit DAC
By 5th order , you mean 5th order Δ-Σ Modulation ?
Mayank
