Sep 17th, 2024, 6:54pm
Pages: 1 2
Why while testing an AMPLIFIER (test chip) in feedback configuration both R-C fe (Read 15557 times)
Manas
Bangalore,INDIA
Feb 15th, 2010, 2:51am
Why while testing an AMPLIFIER (test chip) in feedback configuration both R-C feed back circuit is used.
Please see the attached file for the Diagram.
View Profile Manas   IP Logged
raja.cedt
Re: Why while testing an AMPLIFIER (test chip) in feedback configuration both R-C fe
Reply #1 - Feb 15th, 2010, 4:05am
hi mans,
            due to op amp input parasitic capacitance, if you use only resistive divider you don't see proper step response due to additional pole at the op amp input. So probably they are ding pole zero compensation with the help of this passive network.
rajasekhar.
Manas
Bangalore,INDIA
Reply #2 - Feb 15th, 2010, 11:24pm
Hi Rajsekhar,
So ur telling if we use Resistive feedback the loop-gain Phase is getting degraded due to the i/p Cap of OPAMP and hence the stability and BW. If this is the problem then one can use ONLY Capacitor feed-back and get out of the jail. This can also give the DC -ve Feed-back.Why bother about both RESISTOR and CAPACITOR
Berti
Reply #3 - Feb 16th, 2010, 12:31am
Rajasekhar, can you please elaborate on your answer. Why should the input capacitance of the amplifier degrade settling?
Manas, for which frequencies is this testing configuration used?
I think that the capacitors provide the actual (low) impedance feedback while the resistors are only used to define the DC operating point. Would you use only resistors, the amplifier would be resistively loaded, while using only capacitors, the DC operating point at the input of the amplifier will not be defined.
Manas
Bangalore,INDIA
Reply #4 - Feb 16th, 2010, 12:59am
Berti wrote on Feb 16th, 2010, 12:31am:
Berti,
The testing configuration is used for to Characterize an OPAMP (to find UGB,Slew rate,IM3 and so on). Also these type of configuration is very common. Any paper you open you will find this type of set-up for testing the Chip(OPAMP).
I have some doubts on your Comments-->
1)Why one needs low impedance  feed-back.What does it actually
mean?
2)Why you are saying Cap divider can't give DC biasing point. Two capacitors can divide the DC voltage like Resistive Divider. Isn't It  :)
Reply #5 - Feb 16th, 2010, 2:16am
Manas wrote on Feb 16th, 2010, 12:59am:
Consider a case where an inverted input node is charged.
What voltage do you think it results in ?
If feedback networks are composed of only capacitor,
   - It is difficult to fix DC bias points properly.
     It could results in extreme bias points, e.g. all devices are saturated or cut off.
     This is very true for CMOS OP Amp.
   - No feedback effect at DC and low frequency. It could cause unstability.
If feedback networks are composed of only resistor,
   - It could be unstable for high frequency.
« Last Edit: Feb 16th, 2010, 3:17am by pancho_hideboo »
Manas
Bangalore,INDIA
Reply #6 - Feb 16th, 2010, 3:27am
pancho_hideboo wrote on Feb 16th, 2010, 2:16am:
Thanks A lot,
Just to tell about your question above-->
Suppose the cap (Cin) from inverting node to Gnd(no ac signal) has +ve Charge, then the OPAMP o/p voltage will fall this in turn sucks charge from the inverting node through the F/B CAP(Cf) and the -node will be reverted back to voltage at the + node of the OPAMP as -ve DC feed-back still exists in case of CAP divider.
Just one-thing to mention that Cf/Cin+Cf is equivalent to Rin/Rf+Rin as both are frequency independent.  :)
Reply #7 - Feb 16th, 2010, 3:31am
Manas wrote on Feb 16th, 2010, 3:27am:
I can't understand what you want to claim.
Both charge(Qx) and capacitance(Cx) of inverted node are unknown.
And Qx might be negative.
They are different regarding DC characteristics although they are same regarding AC characteristcs.
« Last Edit: Feb 16th, 2010, 4:51am by pancho_hideboo »
raja.cedt
Reply #8 - Feb 16th, 2010, 6:57am
hi barthi,
             i feel due to op amp input cap there will be one extra pole which may impact Ts...what's the issue in this
thanks
Rajasekhar.
Berti
Reply #9 - Feb 16th, 2010, 11:44pm
Rajasekhar,
This 'feeling' can be resolved by simple hand-calculations. However, since the input cap of the opamp is basically in parallel to the input capacitance I don't see how an additional pole should be created.
Manas, I was wondering about the frequencies of interest since already for reasonably high frequencies (>1MHz) the impedance will be dominated by the capacitor (for the values given in your figure). The resistors therefore only serves to define the DC operating point. - as Pancho explained quite well.
Cheers
Manas
Bangalore,INDIA
Reply #10 - Feb 17th, 2010, 9:52pm
link=1266231079/0#6 date=1266319631]Suppose the cap (Cin) from inverting node to Gnd(no ac signal) has +ve Charge,
as -ve DC feed-back still exists in case of CAP divider. [/quote]I can't understand what you want to claim.
IN RESPONSE TO ABOVE MENTIONED Q-->
I MEAN TO SAY THAT ANY SPURIOUS CHARGE CAN BE REMOVED BECAUSE OF OPAMP ACTION AND IN THE STEADY STATE IT WILL BE SAME AS IF YOU DON'T HAVE ANY CHARGE IN THE CAP.
IN RESPONSE TO ABOVE Qn-->
THE VOLTAGE AT THE ASKED NODE IS --> = Vdd * [C2/(C1+CX+C2)]. AS CHARGE REDISTRIBUTION HAPPENS.
PLEASE NOTE THAT IF C1>>CX (AS MENTIONED IN MY DIAGRAM 2.5pf), THE EFFECT OF Cx CAN BE NEGLECTED AND ONE CAN GET THE DESIRED VOLTAGE DIVISION.
Manas
Bangalore,INDIA
Reply #11 - Feb 17th, 2010, 9:58pm
raja.cedt wrote on Feb 16th, 2010, 6:57am:
hi barthi,
thanks
Rajasekhar.
Rajasekhar
Why you r telling there will be pole ? if there is no resistor feed-back ??
Don't u think one can give DC -ve feed-back with CAP only ??
Manas
Bangalore,INDIA
Reply #12 - Feb 17th, 2010, 9:58pm
hi barthi,
thanks
Rajasekhar.
Rajasekhar
Reply #13 - Feb 18th, 2010, 12:48am
Manas wrote on Feb 17th, 2010, 9:52pm:
Not correct.
First, Vx is a floating node. So Qx can not be removed.
Second, it could result in stagnated bias points. So OP Amp can't work correctly.
Not correct.
C1, C2 and Cx share Qx in initial state.
Qx is not charged in only small Cx.
So after restribution of charge, I can't expect Vx correctly.
Manas wrote on Feb 17th, 2010, 9:58pm:
Again, there is no feedback for DC if feedback network is composed of only capacitor.
« Last Edit: Feb 18th, 2010, 3:51am by pancho_hideboo »
Reply #14 - Feb 18th, 2010, 12:53am
The following is duplicated. Please delete this post.
http://www.designers-guide.org/Forum/YaBB.pl?num=1266231079/12#12
Pages: 1 2
