Jul 17th, 2024, 10:31am
help with syntax (Read 4180 times)
manikandan
help with syntax
Feb 16th, 2010, 12:52pm
hi
how can this logic be implemented in verilog A..
if(voltage input high )
condition 1
elseif(voltage input low)
condition 2
Re: help with syntax
Reply #1 - Feb 16th, 2010, 2:46pm
module mymod(in);
input in;
electrical in;
parameter real vhigh = 0.7;
parameter real vlow = 0.3;
analog begin
if (V(in) > vhigh)
 statement1;
else if (V(in) < vlow)
 statement2;
manikandan
Reply #2 - Feb 17th, 2010, 2:00am
i got this error..pls help me fix it..according to voltage in i want the division ratio to change..
`include "constants.vams"
`include "disciplines.vams"
module freqdividerduty(out, vcoin, in);
output out; voltage out;    // output
input vcoin; voltage vcoin;        // input (edge triggered)
input in; voltage in;
parameter real vh=+3.3;        // output voltage in high state
parameter real vl=0;        // output voltage in low state
parameter real vth=(vh+vl)/2;    // threshold voltage at input
parameter integer ratioone=40 from [40:inf);    // divide ratio
parameter integer ratiotwo=41 from [40:inf);    // divide ratio
parameter real tt=1n from (0:inf);    // transition time of output signal
parameter real td=0 from [0:inf);    // average delay from input to output
integer count,x,y;
analog begin
   @(cross(V(vcoin) - vth, +1)) begin
   count = count + 1; // count input transitions
   if (count >= y)
       count = 0;
if (count <= (y/2)) begin
x = 1;
else begin
x = 0;
if (V(in) = vh)
y = ratioone;
elseif (V(in) = vl)
y = ratiotwo;
else
y = 0;
   V(out) <+ transition(x ? vh : vl, td, tt);
"/proj/ek/vlsi4/common_libs/project_main_shared/freqdividerduty/veriloga/verilog
a.va",
       line 22: Warning: (Archaic Syntax) Does not comply with the Accellera
       Verilog-AMS 2.0 Standard and beyond. To comply with the current
       standard, assign a value to `y'. A variable that is never assigned a
       value is considered a digital variable in Verilog-AMS and is therefore
       not pure Verilog-A.
Error found by spectre during SpectreHDL compile.
a.va",
       line 39: "if<<--?  (V(in) = vh)"
a.va",
       line 39: Error: syntax error
   Maximum allowable errors exceeded.  Exiting AHDL compilation....
Reply #3 - Feb 17th, 2010, 3:02am
If you actually indented your code (consistently), it would make it much easier for you to identify the mistake which is causing this (and then uncover the subsequent errors).
First thing, look around the line where the problem occurs:
x = 0;
if (V(in) = vh)
You have two successive end statements. The second of these is closing the begin associated with the analog statement. So it shouldn't be there.
Having fixed that, you have some other issues
if (V(in) =  vth)
You've used an assignment rather than an equality check (==) in this statement. That said, using an equality check is not a good idea, because you would be attempting to compare a solved floating point number with a floating point constant. You should never do equality checks on floating point numbers (in pretty much any language) and even more so when one of them is numerically solved. You should check within a tolerance. I would suggest either doing:
if (abs(V(in)-vh)<1e-3)
i.e. give a tolerance on the comparison. Or maybe even:
if (V(in) >= vh)
  y = ratioone;
else if (V(in) <= vl)
  y = ratiotwo;
else
  y = 0;
Note also that I changed the elseif to else if because that's also incorrect.
I didn't check the correctness of the model itself. Looks simple enough.
