Aug 15th, 2024, 5:06pm
foreach command cshell scripting (Read 1061 times)
avlsi
singapore
Feb 17th, 2010, 10:43pm
Hi everyone,
                  In my cshell script, there are few foreach loops in which few commands gets executed. It is written as
foreach vds ( 1.1 1.2)
foreach temp ( 27.0 126.0)
commands
But when i execute the script by sourcing it..There are errors saying
foreach: Words not parentisized
Please help me to solve the error.
Thanks in advance.
Winners never Quit,Quitters never Win
Re: foreach command cshell scripting
Reply #1 - Feb 17th, 2010, 11:51pm
What you typed looks okay to me. Use
set echo
before the for loops to see on which statement the error occurs.
avlsi
singapore
Reply #2 - Feb 18th, 2010, 12:12am
Hi Ken,
          when i put echo in front of foreach loops.The error is Badly Placed ()'s.
          One more issue in my cshell script is, i have commands like mkdir file1. But the created directory name is file1? . I dont understand why the file is created in this way.
Thanks for ur prompt reply.
boe
Reply #3 - Feb 18th, 2010, 5:07am
avlsi,
You probably have an invisible control character at the end of your line, e.g. CR (^M, 0x0D).
BOE
Reply #4 - Feb 18th, 2010, 12:49pm
I was suggesting that you use echo to identify the offending line.
Avlsi might be on to something. Perhaps you are using a file formatted for windows or mac on unix, or visaversa. Try opening the file in vi, then type
:set ff=unix
:wq
and try again.
Is there some reason why you don't just post the script? It would be much easier to help you if we did not have to guess what you were doing.
