The question is a bit confusing. It would probably help to know how you're running the corners. Is this IC5141 or IC61X? Are you running Tools->Corners from ADE, or using Corners within ADE XL within IC613/IC614? Or are you using VSDE from IC5141 to set up your corners? Or are you using some custom tool to do this?
How are you setting up the corners - how are they defined?
Generally speaking, if you're using the corners tool (in, say, IC5141), then that will be responsible for defining which model files and sections are being used. So if you're adding your file as an additional model file in ADE, then it probably is not being included. I think if you add it as a "definition file" (under Setup->Simulation Files in ADE) then it will get included.
But this is just guess work - I don't know what version of anything you're using, or which tools, so it's really hard to give a precise answer.
