Jul 17th, 2024, 8:35am
Clock speed change (Read 1805 times)
JrWin
Clock speed change
Mar 07th, 2010, 6:47pm
I am working on a  CPLD project. The program was originally sending 8-bits data in parallel. Now I have to change it to send the data in serial.
So the clock speed was set to 8 times faster. But the problem is that the
data still have to be read from the buffer in parallel before sending.
The original coding for the parallel data output is as following:
always @ (iPSClk)        // clock for parallel data output
begin
    if(iPSClk)
        oRead = 0;          // triggers read at the falling edge;
    else
        oRead = 1;
Then it was modified for the serial output:
always @(rBitCnt)
begin
    if((rBitCnt == 4) || (rBitCnt == 5) || (rBitCnt == 6) || (rBitCnt == 7))
         oRead = 0;
    else
         oRead = 1;
always @(negedge iPSClk2)    // new clock for serial output
begin
    if(rBitCnt < 7)
         rBitCnt = rBitCnt + 1;
    else
         rBitCnt = 0;
The oRead signals measured by the analyzer are in the same timing, however, the program is not working.
So it will be great help, if anyone knows better ways to remain the oRead timing with new faster clock.
Thank you,
JR
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Clock speed change
Reply #1 - Mar 8th, 2010, 7:03am
This is the section for Verilog-AMS, so that's the mixed-signal extensions to Verilog. Although Verilog 1364-2008 is a full subset of the Verilog-AMS 2.3.1 language, I think you will find that the people that could answer your question normally do not visit this forum.
Cheers,
Marq
