Sep 18th, 2024, 11:20am
designing a Voltage Controlled Oscillator (VCO) (Read 10193 times)
mustakhim
Mar 10th, 2010, 4:22am
hye guys,
I'm looking to design a Voltage Controlled Oscillator (VCO) that meets the below requirements :
-output voltage should be periodic but doesnt matter what shape
-should adjust its frequency in response to input voltage which is 1V-2V.
-input impedance should be more than 10k ohm and output impedance should be less than 1k ohm
-1V produce frequency FL and 2V produce frequency FH
Can anybody give me where is the good place to start? Thanks in advance for any help.
Re: designing a Voltage Controlled Oscillator (VCO)
Reply #1 - Mar 10th, 2010, 4:38pm
min-max frequency?
phase/jitter requirements?
CMOS? Bipolar? 5um or 28nm?
more info needed/
mustakhim
Reply #2 - Mar 12th, 2010, 9:30pm
loose-electron wrote on Mar 10th, 2010, 4:38pm:
min-max frequency?
more info needed/
the min and max frequency is not given yet, its given later during the lab.
The method of doing it is indipendent, and theres restriction in designing it as long as it meets the requirement.
thanks
Reply #3 - Mar 14th, 2010, 12:01pm
um, how do I put this nicely? Why are you coming here to have this forum do your school homework?
Read the instructor provided materiel and study up on the subject.
mustakhim
Reply #4 - Mar 14th, 2010, 3:39pm
loose-electron wrote on Mar 14th, 2010, 12:01pm:
sorry about that, but i just want a rough idea on designing the circuit. The lab exercise is to design the circuit, without giving any additional information rather than the requirements stated above. I post it in this forum just to get some rough idea on how to design the circuit that meets the requirements given. I hope you guys can help me as i'm still learning about electronics.
tkhan
Reply #5 - Mar 14th, 2010, 5:50pm
Reply #6 - Mar 15th, 2010, 2:57pm
some constructive suggestions ---
Google the topic and see whats out there. (duh!)
Start looking into textbooks.
If the design is board level look at whats out there for available components.
Go see:
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_homepage_link=hp_Produ...
and search there for suitable parts.
oermens
Reply #7 - Mar 16th, 2010, 6:11am
You can also find video lectures by Ali Niknejad (UC Berkeley) here: http://webcast.berkeley.edu/course_details.php?seriesid=1906978242
