Jul 17th, 2024, 2:26am
CML/SCL layout (Read 1785 times)
oermens
CML/SCL layout
Mar 11th, 2010, 12:33pm
Hi, I want to do layout of some CML gates. Since there are no standard cells for this logic family (or are there?), what is the best way to do the layout? I figure symmetry is important, what else? Should transistors be drawn on a single active, or as they are arranged in schematic (stacked diff pairs)? Would each diff pair need its own guard ring?
My design works in UHF range.
Thanks.
love_analog
Re: CML/SCL layout
Reply #1 - Apr 7th, 2010, 9:45pm
typically you do common-centriod on the transistors for matching.
I haven't heard of anyone having a "CML" library from a fab.
loveanalog.blogspot.com
The Power of Analog
