Sep 20th, 2026, 5:59am
Simulate slew rate of a fully differentiel amplifier (Read 13517 times)
IvoryDesigner
Mar 11th, 2010, 1:20pm
I'm simulating performances of a fully differential OpAmp, and I would like to know How to simulate the Slew rate. I know how to do it with a single ended OpAmp: Set the OpAmp into follower configuration and enter a pulse at the input and look at the output.
Is it the same with a fully differential OpAmp??
Thank you for your help! Smiley
Re: Simulate slew rate of a fully differentiel amplifier
Reply #1 - Mar 12th, 2010, 10:14pm
Ivory,
  Maybe I am missing something, but why don't you just measure
slew rate of the amplifier in the application test bench? That is, input
a pulse into your circuit and measure the slew rate. The slew rate is
dependent on context, that is, the circuit architecture.
IvoryDesigner
Reply #2 - Mar 13th, 2010, 7:38pm
Hi Sheldon,
Thanks for your answer, that a good point Smiley. I know I can measure the SR of the entire analog chain, but I also want to caracterise the intrinsic performance of the amplifier alone with the load.
Best Regards!!
IvoryDesigner
yvkrishna
Reply #3 - Mar 15th, 2010, 5:45am
Hi Ivory,
apply a differential step at the inputs(each of half the magnitude) and measure slew at the diffferential o/p.
yvkrishna
BackerShu
Reply #4 - Jun 28th, 2010, 5:52pm
Hi Ivory!
This post may give you some reference if you still need it.
http://www.edaboard.com/viewtopic.php?t=373921&sid=4673be3c19446c2a6615a6baa5404...
By the way, I think sheldon's is much more proper to get the real SR spec of the OPAMP, since the exact environment of it can't be easily built, such as the C load, the influence of the clock signal if the circuit has one.
