Dec 17th, 2025, 12:59am
Pnoise sims. for CDS SC integrator (Read 2869 times)
mvaibhav
Mar 12th, 2010, 2:37am
I'm trying to simulate a SC integrator with correlated double sampling technique using Cadence SpectreRF. I used pss-pnoise simulations but I don't see any noise shaping from 0-fs/2 in the autozeroing phase as I would expect due to the PSD shaping function of CDS -- 2(1-cos2pifT). I tried both "sources" and "tdomain" pnoise.
Thanks.
« Last Edit: Mar 12th, 2010, 9:47am by mvaibhav »
mvaibhav
Re: Pnoise sims. for CDS SC integrator
Reply #1 - Mar 12th, 2010, 3:31am
Analysis statements:
   tnom=25 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
   checklimitdest=psf
pss  pss  fund=100M  harms=100  errpreset=moderate  saveinit=yes
+    writefinal="final.ic"  swapfile="swap"  method=gear2only
+    annotate=status
pnoise  (  net0140  net0112  )  pnoise  start=1  stop=50M  dec=10
+       maxsideband=100  annotate=status
Signal sources (only clocks active):
V14 (phi2 0) vsource type=pulse val0=0 val1=1.5 period=10.0n delay=0 \
       rise=150.00p fall=150.00p width=4.0n
V15 (phi1 0) vsource type=pulse val0=0 val1=1.4 period=10.0n delay=4.9n \
       rise=150.00p fall=150.00p width=4.5n
