Visjnoe
Dear all,
I'm thinking about the test interface of a wideband (~500MHz) IQ differential signal path. What do you consider the best approach to test this, both from the on-chip as off-chip perspective?
I was considering the use of (tapered) source followers to drive the signal off chip (probably will have to drive a few pF's) and than to measure it using an active probe.
Another option would be to feed it (also using source followers) into an off-chip voltage buffer/amplifier. Unfortunately, it's apparently hard to find components that provide a high input impedance + the required bandwidth. Furthermore, most datasheets don't mention input capacitance.
Specifically, on the on-chip test buffers (~source followers) do you see any specific disadvantage/advantage of using DC coupling or AC coupling?
