Apr 26th, 2024, 12:18am
Pages: 1 2
MOSFET LEVEL 3 verilogA model help! (Read 4828 times)
marekm
Re: MOSFET LEVEL 3 verilogA model help!
Reply #15 - Jun 21st, 2010, 11:30am
The multiplicity should be handled by the simulator, not the device.
Marek Mierzwinski
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #16 - Jun 23rd, 2010, 12:37am
Multiplicity is already available through the $mfactor hierarchical system parameter in Verilog-A. Some simulators support aliasing the $mfactor, i.e.
  (* desc="Number of devices in parallel.", units="" *)
  aliasparam m = $mfactor;
You can just use the $mfactor as any other (instance) parameter in the instantiation of the Verilog-A model in your netlist.
Cheers,
Marq
sachin
Reply #17 - Nov 20th, 2017, 10:23pm
Is there a way to use the above model as nmos or pmos?
If yes, then how?
Reply #18 - Nov 22nd, 2017, 7:44am
_TYPE=1 should be NMOS, _TYPE=-1 PMOS. (That may be backwards from your expectation, but MOS model equations are generally written for N-type devices, so it's the P-type that need the sign change.)
Pages: 1 2
