Jul 19th, 2024, 6:29am
PCB Design Company (Read 3812 times)
bhavuli
PCB Design Company
Mar 17th, 2010, 12:20pm
Hi Folks,
I have a few packaged chips that I would like to interconnect on a PCB. The system is designed for 10 Gb/s.
I was wondering if any of you would happen to know a company that specializes in integrating these components on a single PCB at the targeted frequency/bit rate?
Thank you for you time!
Best regards,
Bhavin
Re: PCB Design Company
Reply #1 - Mar 17th, 2010, 4:11pm
lots of place do. Where are you located?
bhavuli
Reply #2 - Mar 18th, 2010, 7:24am
Hi loose-electron,
I am located in Montreal, Canada.
Bhavuli
Reply #3 - Mar 19th, 2010, 9:34am
OK, contact Ken Martin at the University of Toronto - He probably can direct you to someone - Yes Toronto is not close by but its the best I can suggest.
Other options -  Do a search for mixed signal designers local to you, or push come to shove down in the Boston area.
There is probably someone near to Montreal, but thats what I can offer
bon chance!
jerry
bhavuli
Reply #4 - Mar 19th, 2010, 9:45am
Merci beacoup loose-electron!
Best regards,
Bhavuli
Reply #5 - Mar 22nd, 2010, 2:46pm
ce n'est pas une probleme
bonne chance avec cette
(god my french is getting rusty!)  :D
