Jul 18th, 2024, 1:18am
How do i give A differential current input in ADS? (Read 2661 times)
Turin
Greece
Mar 18th, 2010, 4:01pm
How do i give A differential current input in ADS2004?My guess would be to use 2 of the I_AC(freq domain sources) in ads but i'm not sure what to put in  I=Polar(x,x) and freq  parameters.
Also how can I measure current gain and current in general in the ads. Is there any other way besides I_probes?
Thanks....
Re: How do i give A differential current input in ADS?
Reply #1 - Mar 19th, 2010, 8:29am
Turin wrote on Mar 18th, 2010, 4:01pm:
Have you been able to resolve the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1222115512
http://www.designers-guide.org/Forum/YaBB.pl?num=1241539594
You already implement differential current by using two "I_AC" in the above.
but i'm not sure what to put in  IIac=Polarpolar(x,x) and freqFreq  parameters.
Iac=polar(1, 0) and Iac=polar(1, 180)
or
Iac=1 and Iac=-1
Here you can choose any "units" such as "A", "mA", "uA", "pA" and "fA" as well as "unitless".
"Freq" parameter is used for FCAC(Frequency-Converting AC analysis).
Leave it default value, "freq" for conventional AC analysis like following.
Freq=freq (global analysis frequency)
Read documents of Agilent ADS surely.
The followings are documents of Agilent ADS2009. But these are also valid for ADS2004A.
http://edocs.soco.agilent.com/display/ads2009/I+AC+%28AC+current+source%29
http://edocs.soco.agilent.com/display/ads2009/polar%28%29+Expression
http://edocs.soco.agilent.com/display/ads2009/AC+Simulation+Description
http://edocs.soco.agilent.com/display/ads2009/Performing+an+AC+Simulation
Is there any other way besides I_probesI_Probe?
We can save pin currents without inserting "I_Probe" in current ADS.
But you have to insert "I_Probe" since you use ADS2004A.
« Last Edit: Mar 19th, 2010, 10:34am by pancho_hideboo »
Turin
Greece
Reply #2 - Mar 23rd, 2010, 5:25pm
I have completely forgotten about asking these thing again...it been so long ago and i didn't end up using ads back then.
Thanks a lot...
