Nov 10th, 2026, 7:46pm
Question about noise type "sources" of Pnoise (Read 2159 times)
lunren
Asia
Mar 22nd, 2010, 4:48pm
Hi All,
I try to use type sources of pnoise to simulate the noise performance of a switched capacitor circuit, which includes reset and gain modes. I don't care about the noise in reset mode and only care about the noise in gain mode. I have the timedomain results, and want to compare the results with type sources.
In terms of type sources, I have two questions:
1) in order to get the noise in gain mode, should I add a verilogA model of sample&hold at the circuit's output to get the signal only in gain mode?
2) if without the sample&hold circuit, the rmsNoise value of the noise at the output of the circuit I got is the average value IN one PSS period, is that correct? If this is true, this rmsNoise value is the average value of reset and gain mode, it is not the pure noise of gain mode, right?
Here are some results I got for reference. According to timedomain simulation, the noise is about 610uV in gain mode, the sources (with sample&hold) simulation gives 634uV and the sources (without sample&hold) gives 475uV.
Lunren
« Last Edit: Mar 22nd, 2010, 8:57pm by lunren »
Lunren
